文章
Surface inspection annotation in BuildIT
1 - IsoNoAnnot
BuildIT allows users to perform quick and easy inspections. It also enables users to perform analysis and produce reports that are both detailed and simple to generate.
The Surface Inspection Annotation command is a good example of BuildIT’s ease of use. Without performing a complete analysis on a part or an entity you are inspecting, you can evaluate a single measurement at a time. This command also allows you to manually annotate measurements in order to convey information in a way that is clear and simple.
Using our ModelX taken from our example models (Accessible through File: Example Models: ModelX), let’s use the Surface Inspection Annotation to evaluate points taken on the surface highlighted in light blue. This command is accessible through Evaluate: Annotations: Surface Inspection Annotation.
Below, I have set a surface inspection annotation on a single point taken from a cloud that was generated while inspecting the blue surface. I have chosen the option to Show Full Annotation in order to display the deviations along each axis, as well as the absolute deviation and a custom inspection note.
Surface inspection
Surface inspection
Since the current coordinate system is square with the plane, the dX and dY deviations are zero and the absolute deviation is equal to the Z deviation. Therefore, we will not be using any superfluous information in the annotations for the rest of this example.
This method of annotating the surface can be used multiple times to annotate every point in the cloud – in this example, we do not have a lot of measurements. Using the filters, it is also possible to select All Points from Cloud at once, making the annotation process much faster.
All points from Cloud in command
Once all points have been annotated, it is still possible to edit any of them manually afterwards to annotate them individually.
ISO All points and 1 custom
文章
制造
质量控制和检测
航空航天
汽车
软件 - 测量与质量控制
质量控制和检测 (BP)
倡导
筛选
筛选
비디오
Regal Marine이 FARO® Leap ST® 3D 스캐너로 파장을 일으키다
Regal Marine이 Leap ST 핸드헬드 스캐너를 워크플로에 통합하여 품질과 효율성을 향상시킴으로써 보트 제조를 어떻게 혁신하고 있는지 알아보세요.
독일 대형 운송 제조업체가 3D 스캐닝을 활용하는 방법
독일의 중장비 운송 전문업체 Scheuerle Fahrzeugfabrik이 조립 워크플로 개선을 위해 FARO® Focus Laser Scanner와 Vantage Laser Tracker를 어떻게 사용하는지 알아보세요.
웨비나 녹화영상
도약(Leap)하기 전에 확인해 보세요! 변화하는 인력을 위한 새로운 도구입니다.
FARO® Leap ST가 뛰어난 정확성과 탁월한 사용 편의성을 바탕으로 여러 세대가 함께 활용할 수 있는 이상적인 3D 측정 도구인 이유를 알아보세요.
