웨비나/프레젠테이션 녹화
Creating compelling 2D and 3D deliverables from a single photo
다운로드 준비가 거의 완료되었습니다!
이 콘텐츠에 액세스하려면 사용자 정보를 좀 더 알려주세요.
Are you getting the most out of your field evidence?
Did you know that even without a laser scanner, you can use FARO® Zone 3D Software to create impressive, easily sharable visuals for your next case or presentation?
Starting with a simple photograph, you can use FARO Zone 3D Software to turn that photo into an animation, generate measurement reports from it, create report diagrams, do time-distance studies, perform skid analysis and much more.
Attend this webinar to learn how to create different 2D and 3D deliverables, all from one single image.
Most importantly, the final product is sharable to anyone, without them having to have access to any special software or access requirements. It’s an excellent way to present your hard work to the world in a graphically compelling fashion.
법정 발표
사고 충돌 재구성
범죄 현장 조사
인식
수집
재구성 및 분석
FARO 구역
소프트웨어 - 공공 안전 및 포렌식
웨비나/프레젠테이션 녹화
공용 안전 분석
