웨비나/프레젠테이션 녹화
Getting Started with Flatness Check On-Demand Webcast
다운로드 준비가 거의 완료되었습니다!
이 콘텐츠에 액세스하려면 사용자 정보를 좀 더 알려주세요.
As a concrete professional, you know it’s critical for you to be able to evaluate the quality of your pour immediately before it even begins to set. The FARO Flatness Check application lets you perform quick and accurate validations of the pour so you can identify any areas needing rework. Using the iPad, you can easily visualize and smooth any deviations on-site while leaving the in-depth analysis and documentation work to the back office. Watch this quick 25-minute webcast in which our industry expert, Kyle Tarr will take you through the app and demonstrate how it will benefit your on-site operations.
Watch to learn:
  • What the Flatness Check app does and why it’s important
  • How Flatness Check complements your current workflow
  • How Flatness Check works using a real-time demo
  • How the app can be leveraged for multiple use cases
Presenter:
Kyle Tarr
Sr. Business Development Manager, FARO Technologies Inc.
Kyle is a member of the Business Development team at FARO and is focused on the Architecture, Engineering, and Construction industries. He is a Certified General Contractor and has spent the past 8 years building some of Florida’s tallest and most demanding projects. Kyle brings industry technical knowledge to FARO to better serve the industry.
웨비나/프레젠테이션 녹화
건설 품질 관리
건축, 엔지니어링, 건설
FARO Sphere
소프트웨어 - 건축, 엔지니어링 및 건설
건축, 엔지니어링 및 건설
엔지니어링 및 설계
