웨비나/프레젠테이션 녹화
Hybrid Reality Capture™ Powered by Flash Technology™
다운로드 준비가 거의 완료되었습니다!
이 콘텐츠에 액세스하려면 사용자 정보를 좀 더 알려주세요.
Join FARO®’s Shameer Mohamed for an engaging look at the new Hybrid Reality Capture, powered by Flash Technology.
The live event (held November 2) instructed attendees on how to get the most out of this revolutionary upgrade when using a FARO Focus Premium Laser Scanner and also how to access the new scan mode in the Stream Mobile app. Ideal for large-volume scanning, see how an up to 50% time savings will transform your 3D laser scanning projects and which applications will benefit most from this new workflow.
Watch this webinar to learn:
  • How to create striking as-built documentation with enhanced productivity
  • How to access the new scan mode on the FARO Focus Premium Laser Scanner
  • How to capture large-volume scanning for as-built environments
  • Which applications will benefit most from this new workflow
  • How Hybrid Reality Capture works and valuable best practices
Presenter:
Shameer Mohamed
Shameer Mohamed - Field Application Engineer | FARO Singapore
Shameer Mohamed is a FARO FAE with 7 years experience and has been providing CAD/CAM and laser scanning technology solutions to manufacturing and related industries, focusing on Southeast Asia.
준공 캡처 및 모델링
인식
건축 및 건설
엔지니어링 및 설계
측량 및 측정
건축, 엔지니어링, 건설
초점
3D 스캐너
건축, 엔지니어링 및 건설
소프트웨어 - 건축, 엔지니어링 및 건설
웨비나/프레젠테이션 녹화
