웨비나/프레젠테이션 녹화
Fit Out for the Future: Develop Your Reality Capture Workflow
다운로드 준비가 거의 완료되었습니다!
이 콘텐츠에 액세스하려면 사용자 정보를 좀 더 알려주세요.
Join FARO®’s experts for an engaging webinar designed to help you learn about the benefits of 3D laser scanning as it applies to MEP building systems.
This livestream recording detail how to use FARO hardware and software solutions to collect, use, and share data on your jobsite.
Watch this video to learn:
  • How to use the FARO Focus Laser Scanner to capture the physical components of an MEP system.
  • How to use As-Built Software to compare 3D models to in-field MEP installations as well as to create MEP system drawings.
  • How these tools apply to MEP installations or fit outs in oil & gas refineries, water treatment, industrial, and plant environments, as well as installation of technology in an as-built environment.
  • How to make your 3D data sharing manageable, efficient, and easy — including the tools available to project managers and operational teams to progress a ""fit out"" project.
PRESENTERS:
Adam North
Adam North | Account Manager | FARO Technologies
Adam North is an Account Manager at FARO Technologies with expertise in both the Public Safety Analytics and Architecture, Engineering, Construction, and Operations segments.
Matthew Davies
Matthew Davies | Senior Account Manager | FARO Technologies
Matthew Davies is a Senior Account Manager for FARO Technologies. He has experience in industrial metrology and Architecture, Engineering, Construction, and Operations.
Paul Challis
Paul Challis | Account Manager | FARO Technologies
Paul Challis has over 20 years of experience in surveying, with expertise in 3D laser scanning, SLAM, land surveying, and more. He is a member of the Chartered Institute of Civil Engineering Surveys (CICES).
웨비나/프레젠테이션 녹화
준공 캡처 및 모델링
제품 설계 및 엔지니어링
생산, 제조, 조립
인식
엔지니어링 및 설계
건축 및 건설
건축, 엔지니어링, 건설
초점
3D 스캐너
소프트웨어 - 건축, 엔지니어링 및 건설
건축, 엔지니어링 및 건설
비디오
