Weißes Papier
Laser scanning wet concrete for quality control
WHITEPAPER:
Imagine being able to identify and locate high and low areas of wet concrete, and fixing these areas before the concrete dries. By using a 3D laser scanner with fast data acquisition capabilities, combined with software which delivers quick and reliable results, a proven workflow is now possible. This whitepaper walks through the process of adding the FARO® Focus Laser Scanner to a concrete pour workflow to immediately identify high and low areas which can be fixed while still wet.
Weißes Papier
Qualitätskontrolle Baugewerbe
3D-Scanner
Bau und Konstruktion
Inbetrachtziehung
Filter
Filter
Best Practices for 3D Scan Survey Control with FARO Solutions
Master survey control to enhance accuracy, reduce errors, and boost efficiency in AEC projects with advanced laser scanning techniques.
INFOGRAPHIC
Getting Started with Blink
Check out this infographic to see how Blink makes capturing and sharing reality data as easy as taking a photo.
