記事
Precision alignment supports cost reduction & profit margin expansion
AM VantageS Tracking SMR Inspect5 FM Application HR-1024x683
One key to delivering a FARO® precision solution is to first understand an operation’s critical components and the associated cost-contributing challenges. To best exemplify, I want to share excerpts and summaries communicated to me from a recipient of the FARO Laser Tracker solution for precision machinery alignment.
Why Alignment is Important
Proper alignment in a manufacturing facility greatly reduces maintenance costs. When bearings, motors, couplings, etc. are not properly aligned they operate under tension or load conditions. This increases the stress that is created naturally when something mechanical is in motion. Some of this stress is caused by friction and improper alignment increases in the friction. Increased friction and load greatly reduces the cycle life of these components; leading to frequent repairs or replacements of the components.
Benefits of Precision Alignment
In addition, proper alignment generally allows you to run the equipment at higher speeds. Higher speed means higher production, which results in higher profits for the company. When you do the math on it, lower maintenance costs plus higher production levels equals a winning situation for a manufacturing facility.
Criticality of Alignment
In our environment, alignment is even more critical. When you operate an aluminum rolling mill, you pull aluminum thru a series of hydraulic presses. These presses are actually large rollers which forced down into each with hydraulic oil. The goal is to make the aluminum thinner (about the thickness of a beer can). We feed the mill from a coil of aluminum called a payoff reel. At the exit end, we wind it back up on another coil called a rewind. The aluminum travels thru the mill at a rate of about 3000 feet per minute. If the rollers in the mill are not properly aligned, the material will not track straight through the mill. If the material doesn’t track straight, it won’t rewind straight. If the coil is not rewound straight, it’s difficult to handle and ship (the coils weigh roughly 35000 pounds).
Quality from Alignment
Also, if the material does not track straight through the mill, it tends to not hold the shape we are looking for in our product. It has a huge effect on the gauge (thickness) of the aluminum. Our end product has to have consistent shape, or thickness, to meet our customer requirements.
Results!
The accuracy in alignment that we have been able to achieve since we switched to laser tracker alignment has been an asset to our production efforts. The time required to perform a laser alignment is also much less than we previously experienced while using optical alignment equipment.
In summary, the solution begins with an in-depth education and focus on the operations and its critical production processes. We can’t improve, fix, or advance a process without first understanding the “why” or the importance it holds both for stability in a production run to the bottom line profitability of the business.
記事
製造
品質管理と検査
航空宇宙
自動車
エネルギーと天然資源
重機
測定サービス事業
金属加工、機械加工&アセンブリ
ゴムとプラスチック
造船
レーザートラッカー
品質管理と検査(BP)
擁護者
ニュースレターを購読して最新情報を入手してください。
関連コンテンツ
フィルタ
フィルタ
비디오
Regal Marine이 FARO® Leap ST® 3D 스캐너로 파장을 일으키다
Regal Marine이 Leap ST 핸드헬드 스캐너를 워크플로에 통합하여 품질과 효율성을 향상시킴으로써 보트 제조를 어떻게 혁신하고 있는지 알아보세요.
독일 대형 운송 제조업체가 3D 스캐닝을 활용하는 방법
독일의 중장비 운송 전문업체 Scheuerle Fahrzeugfabrik이 조립 워크플로 개선을 위해 FARO® Focus Laser Scanner와 Vantage Laser Tracker를 어떻게 사용하는지 알아보세요.
웨비나 녹화영상
도약(Leap)하기 전에 확인해 보세요! 변화하는 인력을 위한 새로운 도구입니다.
FARO® Leap ST가 뛰어난 정확성과 탁월한 사용 편의성을 바탕으로 여러 세대가 함께 활용할 수 있는 이상적인 3D 측정 도구인 이유를 알아보세요.
