The Hidden Costs of Inaccurate Infrastructure Surveys
Infrastructure projects today are more complex than ever. Surveying professionals are under pressure to keep work on schedule and mitigate downstream problems by delivering fast, accurate, and reliable data.
With challenges such as tighter safety and environment regulations, heightened stakeholder scrutiny, increased project scale, as well as costs and shortages of labor, surveying teams have their work cut out for them. At the center lies the foundation teams rely on—trustworthy infrastructure surveys that support confident decisions.
How Do Accurate Infrastructure Surveys Lead to Cost Savings?
Infrastructure surveys provide the spatial data and insights needed to design, plan, and execute projects. When that data is accurate, the benefits can be immediately felt across the entire project lifecycle. From reducing unexpected costs by avoiding rework to eliminating safety risks and operational inefficiencies, high-quality survey data catch problems earlier that are often difficult and expensive to fix.
What Is Infrastructure Surveying and Why Does Accuracy Matter?
An infrastructure survey is the process of collecting precise spatial data to support the planning, design, and construction of infrastructure such as roads, bridges, railways, and utilities. It plays a critical role in mapping existing structures, guiding construction, and enabling long-term asset management.
In the past, infrastructure survey data was primarily collected using manual and line-of-sight methods, such as total stations, measuring tapes, levels, and GPS equipment. Surveyors would physically move across sites to capture individual data points, often requiring multiple setups to cover larger or more complex areas. As a result, capturing comprehensive site information could take days or even weeks, and any missing or inaccurate data often meant returning to the site for additional measurements.
Accuracy is especially important in the early stages of a project because every downstream decision relies on the integrity of that initial data. For example, a small miscalculation in elevation or alignment can lead to design errors, material waste, and construction delays. Over time, these issues become costly to resolve, which is why accurate data is not just a technical requirement but a strategic necessity.
What Are the Real Costs of Inaccurate Infrastructure Surveys?
    Financial Implications
    One of the most immediate impacts of inaccurate survey data is financial, but the true cost often goes beyond what’s visible on a project budget.
    Inaccurate data frequently leads to rework, such as redesigning plans, re-measuring sites, and correcting construction mistakes. These activities consume additional labor, extend timelines, and increase equipment usage. In some cases, they can even result in contractual disputes or penalties due to missed deadlines.
    There are also hidden costs associated with poor data. For example:
    • Crews may need to revisit sites multiple times.
    • Equipment may sit idle while issues are resolved.
    • Teams may spend hours reconciling inconsistent datasets.
    These inefficiencies add quickly, eroding profitability.
    Safety Risks
    Beyond financial implications, accurate surveys also reduce safety risks, particularly on construction sites.
    Complete and correct survey data help detect hazards, creating safer working conditions, better planning, and lowered exposure for field crews operating in high-risk environments. For instance, having comprehensive data on terrain, structures, or utilities reduces dangerous assumptions during construction, preventing crews from unknowingly work near unstable ground or unmarked obstacles.
    Accurate surveying also reduces the need for repeated site visits and enables more work to be done remotely, minimizing time spent in hazardous conditions and improving overall site safety in alignment with government safety regulations such as OSHA.
    Efficiency Losses
    Accurate infrastructure surveys also boost efficiency. Good survey data allows for:
    • Reduced site revisits to verify or correct measurements.
    • Better alignment between different teams and stakeholders.
    • Less delays in decision-making due to having complete overview of the same information.
Modern surveying software and fully connected workflows effectively address the challenge of silos, creating an environment where information is consistent and complete. The result is an agile, unified project lifecycle, where teams spend more time being proactive instead of reactive.
Building Accurate Infrastructure Survey Workflows
Understanding the root causes of inaccuracies is the first step toward improving survey outcomes. Here are key areas where improvements can drive more accurate and reliable infrastructure surveys:
    Upgrading to Modern Land Surveying Tools
    Today's advanced land surveying tools are designed for precision, speed, and scalability, allowing teams to capture higher quality data in less time. Modern surveying solutions, such as those offered by FARO INSIGHT, provide the tools to capture data, the means to process automatically, and the ways to gain insight from the mass of information.
    Adapting to Environmental Challenges
    When dealing with different environments, solutions tailor-made for that specific use case help ensure consistent, high-quality data capture. For example, consider FARO INSIGHT’s range of scanners, covering a wide range of environments.
    For highly complex environments that require maximum precision, terrestrial laser scanning (TLS) delivers detailed, high-accuracy data capture. When speed and coverage are critical, such as in large infrastructure corridors, mobile laser scanning (MLS) enables rapid data collection over expansive areas. Meanwhile, imaging laser scanning (ILS) provides high-quality visual data, making it ideal for frequent progress tracking and clear documentation.
    In summary:
    Environment Type Best Survey Method Benefit
    Complex, high-precision areas Terrestrial Laser Scanning (TLS) Maximum accuracy
    Large corridors MLS (Mobile Laser Scanning) Speed and coverage
    Frequent documentation Imaging Laser Scanning (ILS) Visual clarity
    Connecting Workflows with Integrated Surveying Software
    Integrated surveying software platforms create a single source of truth: a reliable information source with data that’s up to date with the most recent imported site capture. This streamlines how data is processed and shared, helping teams reduce inconsistencies and improve collaboration. Software that cohabits the same digital ecosystem, such as FARO Sphere XG, helps reduce errors and improves collaboration between teams.
Is Accuracy a Competitive Advantage?
Accurate infrastructure surveys reduce financial losses, safety risks, and operational inefficiencies, which have an impact that can be felt at every stage. It enables better decision-making, improves safety, and ensures projects are completed on time and within budget, providing a clear competitive advantage.
As infrastructure projects continue to grow in complexity, the need for precision will only increase. Investing in accurate, reliable surveying solutions is more than just avoiding problems, but also about positioning your team for long-term success. FARO INSIGHT provides innovative geospatial technology that supports long-term success by making your work easier, faster, and more accurate.
Check out our infographic on reality capture for infrastructure surveys to discover more ways you can optimize your infrastructure survey workflows for greater efficiency.
View Infographic
Geospatial
Orbis
Blink
FARO Sphere
Rovi
