Heritage scanning in Curacao with mobile LiDAR
Lady scanning a construction site with a mobile LiDAR scanner
Providing Healthcare to a Caribbean Island since the 19th century
Constructed in 1855 with the help of the Franciscan sisters, the St. Elisabeth hospital has played an important role in the Otrobanda City district on the Caribbean Island of Curaçao, for over 160 years. The large hospital served as the main hub for medical care in Curaçao and historically it was a place of healing for other island nations nearby.
person mapping a large empty room with a mobile LiDAR scanner
No longer fit for purpose according to international standards in 2011, it was decided that a new hospital would be constructed next to St Elisabeth's. In 2019 the Curaçao medical center was opened to the public and the St. Elisabeth hospital was closed in November 2019.
Lady posing with a mobile LiDAR scanner in front of a construction site
Appointed by the survey bureau “Landmark,” Ellen de Brabander from Urban Studio mapped the hospital in anticipation of renovation projects. Ellen chose mobile LiDAR for the task and later created an accurate 3D model using the point cloud data. In addition, Ellen is working on creating a virtual tour of the hospital for virtual reality.
Scanning with Mobile LiDAR
Due to the large, complex nature of the building, with several floors and many individual rooms, the task of capturing the hospital was enormous. The hospital divides into six sub-buildings, an average of three floors per building and individual rooms per floor. Furthermore, with difficult-to-access areas, the versatility of a mobile LiDAR solution was the fastest solution for capturing all areas in a suitable time.
A mobile 3D scanner is ideal due to its lightweight nature, speed of capture and ease of use. Ellen chose a SLAM solution for the job and was able to seamlessly walk through the hospital's complex buildings, capturing data as she moved.
Lady mapping an abandoned building with a mobile LiDAR scanner
“The 3D scanner was able to reduce the time of the measurement and as a result, the delivery time was met. The measurement time would normally take several months, which was reduced to days.”
Having decided on a mobile solution, Ellen captured both the interior and exterior of St. Elisabeth's hospital in six full working days. She conducted 52 scans in total, with each taking approximately 20 minutes. The area covered was 22,346 square meters. The maneuverability and compactness of the scanner made data capture nearly effortless.
Post-Scan
3D BIM model of St. Elisabeth hospital in Curaçao
After processing and merging the data, it was converted using Autodesk® Recap® and imported into Autodesk Revit® for modeling. The client received the model of the hospital within the allotted time frame and to a suitable standard.
As-Built Capture & Modeling
Construction Quality Control
Failure Investigation
Safety Planning
Build & Construct
Surveying & Measurement
Apps & Plug-Ins
Integrated / Partner Solution
Mobile Mapping Systems
Partner Solution
INFOGRAPHIE
Commencer avec Blink
Consultez cette infographie pour découvrir comment Blink rend la capture et le partage de données réelles aussi simples que de prendre une photo.
