Surveying Equipment Tools and Technologies for Accurate Measurement
Surveying has always demanded accuracy, but modern projects require more than just careful measurements — they require reliable, repeatable data that integrate seamlessly into digital workflows. From traditional land boundary surveys to advanced geospatial mapping, today’s surveying equipment reflects decades of evolution, all aimed at improving accuracy, efficiency, and data integrity.
This article breaks down the essential surveying equipment and precision measurement tools used in the field today, from total stations and GNSS receivers to 3D laser scanners and integrated surveying software. Whether you’re working in industries like construction, mining, or forestry, understanding the available toolset is the first step to delivering accurate results.
What Is Surveying Equipment?
Surveying equipment refers to the instruments used by surveyors to determine the three-dimensional position of points, distances between them, and the geometry formed by those points. These tools range from manual devices like total stations and digital levels to cutting-edge systems such as LiDAR technology and drones.
What they all share is a focus on accurate measurement — ensuring that the information gathered in the field is accurate, verifiable, and usable across the entire project lifecycle.
Types of Surveying Equipment for Precision Measurement:
  1. 3D Laser Scanners
  2. 3D laser scanners, like the FARO® Focus Laser Scanning Solution or the FARO Orbis™ Premium Mobile Scanner, use LiDAR (Light Detection and Ranging) to rapidly capture millions of 3D measurement points per second, generating a detailed point cloud of the physical environment.
    This method enables a complete, accurate, digital 3D model of terrain, buildings, or infrastructure. It eliminates many of the time consuming, manual tasks of traditional surveying and allows surveyors to revisit sites - virtually.
  3. Total Stations
  4. Total stations combine electronic distance measurement (EDM) and angular measurement into a single instrument. By using reflectors (or reflectorless technology), total stations calculate distances and angles, enabling the creation of highly accurate site layouts, highway surveys and topographic maps.
    How a total station works: It measures the angle between two points and the distance to points using a laser. With the coordinates of the instrument known, the position of any other visible point can be calculated using trigonometry.
  5. GNSS Receivers
  6. GNSS (Global Navigation Satellite System) receivers use signals from satellite constellations (such as GPS, GLONASS, Galileo) to determine geospatial positions.
    RTK GNSS (Real-Time Kinematic) enhances GNSS accuracy to centimeter-level accuracy by correcting satellite signal errors in real time using a base station and a rover unit.
  7. Surveying Drones
  8. Equipped with LiDAR or cameras, surveying drones allow for rapid data collection over large and/or inaccessible areas. When paired with software like FARO Sphere XG, drone data can be processed and merged with other point cloud data for comprehensive site analysis.
  9. Digital Levels and Theodolites
  10. While not as common as the above systems, digital levels and theodolites remain essential for projects where simplicity, cost-efficiency, and high accuracy are key. These tools help in determining height differences and horizontal/vertical angles manually or with electronic assistance.
  11. Surveying Software
  12. Raw survey data is only valuable when it can be turned into actionable information. Software platforms like FARO SCENE and FARO Sphere® XG allow surveyors to process and register point clouds, merge datasets from different sources, and prepare deliverables such as topographic maps, 3D models, and building information models (BIM).
Choosing the Appropriate Surveying Equipment
Selecting the right surveying tools depends on multiple factors:
  • Environment: Is the job in an open field, urban environment, or wooded area?
  • Accuracy Requirements: Some applications require millimeter accuracy; others can tolerate decimeter levels, or more.
  • Project Size and Duration: Larger projects may benefit from faster capture methods like 3D laser scanning or surveying drones.
  • Data Integration Needs: Does your team need BIM or geographic information system (GIS) compatibility?
It's often not a matter of choosing one tool but combining several into an integrated workflow that maximizes productivity while maintaining the required accuracy.
The Future of Precision Measurement
Today’s surveying instruments are no longer standalone tools. They are part of an integrated digital ecosystem that connects field teams with office stakeholders. Automation, real-time correction, and interoperability are now core to modern surveying technology.
Solutions like FARO’s Flash Technology™ enable high-speed scan capture, while cloud-based platforms like Sphere XG are redefining collaboration and data delivery.
As 3D scanning and GNSS technology continue to advance, surveyors can expect even tighter accuracy, faster workflows, and greater safety in the field.
Final Thoughts
Surveying equipment has come a long way, from optical theodolites to real-time, cloud-connected systems capable of millimeter-level accuracy. In today’s high-stakes projects, the difference between a good result and a great one comes down to the quality of your tools — and the knowledge of how you use them.
For projects that demand accuracy, speed, and verifiable digital records, FARO’s portfolio of precision measurement tools — from the Focus Premium Max to the Orbis Premium Mobile Scanner, and from Connect to Sphere XG — offers everything professionals need to get the job done right.
Explore the future of geospatial workflows:
Visit the Geospatial Landing Page
Mining Services
Risk Management
Surveying & Measurement
Geospatial
Measurement Service Providers
FARO Sphere
Orbis
Flash
